Website X5 Software
- Everything else
- Website X5 Software
Website X5 Software
12-01-2011 9:54 PM
Am using software from Incomedia WebsiteX5 to create a website but am really struggling to get it to export to my Plus Net Webspace. It asks for FTP Address - I have tried to use ftp.plus.net - Also asks for my username and password so I use my Plusnet username and Plusnet password. It then says "Unable to connect to server Please check with you Internet Provider - any thoughts???
Message 1 of 3
(1,448 Views)
2 REPLIES 2
Re: Website X5 Software
15-01-2011 10:30 PM
Does this help? http://www.plus.net/support/hosting/webspace/webspace_details.shtml
You could also try saving the work locally and uploading using a different FTP client. Try Filezilla, for example
Message 2 of 3
(323 Views)
18-01-2011 9:27 AM
Also make sure you use the username and password as you would to log into the website, rather than as you'd put in your router - if you put the connection realm on the end of the username (i.e. username@plusdsl.net) it won't work.
Hope that helps,
Hope that helps,
Message 3 of 3
(323 Views)
