Website Hosting password problem
FIXED- Subscribe to RSS Feed
- Everything else
- Website Hosting password problem
09-08-2019 1:33 AM
I have the (legacy) standard webspace, which I've never needed to use until now.
I set up Filezilla with the FTP settings - the connection was refused. The settings page says:
Password | The password you use to log in to this website |
Oh no it isn't, it is my OLD password that I had when I first took the Plusnet service, i.e. it didn't get updated when I changed my password for the other services (email, http, control panel). Surely a bug?
I don't need it changed - now that I've figured out what it is, but it was more than a little confusing at the time.
Fixed! Go to the fix.
Re: Website Hosting password problem
09-08-2019 10:10 PM
As far as I’m aware when you update your account password this doesn’t automatically update your webspace password, if you want to change that too you’d go to hosting.plus.net
10-08-2019 10:57 PM
@Robot It actually looks like this was an acknowledged issue and we believe to have fixed it on the 6th August. Have you tried to change your account password following then Here then log into your FTP server using that password?
You may need to wait up to 1 hour for the password change to take effect in the webspace component.
10-08-2019 11:32 PM
No - the last time I changed the account password was before December 2015 (I don't have a record of it before then).
Are you saying that I need to change the account password, and now (but only since 6th August) the website password will change to follow it?
To be honest, it isn't worth the hassle to change it and then change it back. I can live with 2 different passwords.
10-08-2019 11:46 PM
- Everything else
