Website Builder
- Everything else
- Website Builder
Website Builder
30-08-2007 3:05 AM
"Website Builder Create your own website with this easy to use tool GO" takes us to?
Re: WEBSITE BUILDER
30-08-2007 8:37 AM
Really the option should be removed until such time as a decision is made.
Re: WEBSITE BUILDER
30-08-2007 9:50 AM
(This forum is "Any ideas or suggestions you have on how we can improve the Community Site should be posted here.")
Edit: Now been moved
Re: WEBSITE BUILDER
30-08-2007 9:55 AM
Quote from: Peter The application was removed due to security issues
Did these relate to the tool itself or to sites built with the tool?
Re: WEBSITE BUILDER
30-08-2007 10:13 AM
Thanks for moving this thread which I erroneously posted to wrong forum.
Re: Website Builder
30-08-2007 10:20 AM
Re: Website Builder
30-08-2007 10:30 AM
Quote from: Brian Create your own website with this easy to use tool
In the current absence of PN's website-building tool, you might find the Arachnophilia site useful -
basic html is at
http://vps.arachnoid.com/lutusp/html_tutor.html
homepage builder 2.0 is at
http://vps.arachnoid.com/lutusp/pagebuild.html
(the homepage builder is literally that, a step-by-step process you do online - very easy - and you can see the results as you change things)
there's also free pagebuilding software - "Arachnophilia" itself
http://vps.arachnoid.com/arachnophilia/index_old.html - there's a java version but I find the old 4.0 version is fine for pagebuilding (and it lets you amend 100-ish pages at a time when your site gets bigger).
Regards,
Penny.
Project HappyChild - free educational resources for children + schools * my own [personal] webpage is at pennymidasrollo.plus.com
Re: Website Builder
30-08-2007 1:15 PM
Quote Moved to webspace help - I have also changed the all caps title, as using all caps is considered rude and shouting.
Thanks Assos. And apologies for my use of all caps. I had inadvertently and thoughtlessly failed to observe the customary style formailites.
Thanks too to Penny for web-builder suggestion.
Regards to all
Re: Website Builder
30-08-2007 1:37 PM
Re: Website Builder
30-08-2007 2:36 PM
I've raised this to our portal team, as the description of the page could do with an update.
In the meantime, we recommend NVU.
Re: Website Builder
30-08-2007 3:10 PM
Re: Website Builder
30-08-2007 11:36 PM
