Website Builder
Website Builder
I know this may sound like a silly request, but could we actually have a Website Builder on the page that your
"Website Builder  Create your own website with this easy to use tool  GO"    takes us to?
11 REPLIES 11
Peter_Vaughan
Re: WEBSITE BUILDER
The application was removed due to security issues and as yet, PN have not decided if a replacement will be offered.
Really the option should be removed until such time as a decision is made.
jelv
Fixes: 10
Re: WEBSITE BUILDER
Could this be moved to the correct forum please?
(This forum is "Any ideas or suggestions you have on how we can improve the Community Site should be posted here.")
Edit: Now been moved
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Simon_M
Re: WEBSITE BUILDER
Quote from: Peter
Did these relate to the tool itself or to sites built with the tool?
Re: WEBSITE BUILDER
To Assos
Thanks for moving this thread which I erroneously posted to wrong forum.
Assos
Re: Website Builder
Moved to webspace help - I have also changed the all caps title, as using all caps is considered rude and shouting.
Penny
Fixes: 8
Re: Website Builder
Quote from: Brian
In the current absence of PN's website-building tool, you might find the Arachnophilia site useful -
basic html is at
http://vps.arachnoid.com/lutusp/html_tutor.html
homepage builder 2.0 is at
http://vps.arachnoid.com/lutusp/pagebuild.html
(the homepage builder is literally that, a step-by-step process you do online - very easy - and you can see the results as you change things)
there's also free pagebuilding software - "Arachnophilia" itself
http://vps.arachnoid.com/arachnophilia/index_old.html - there's a java version but I find the old 4.0 version is fine for pagebuilding (and it lets you amend 100-ish pages at a time when your site gets bigger).
Regards,
Penny.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Re: Website Builder
Thanks Assos. And apologies for my use of all caps. I had inadvertently and thoughtlessly failed to observe the customary style formailites.
Thanks too to Penny for web-builder suggestion.
Regards to all
jelv
Fixes: 10
Re: Website Builder
I've added an edit to my post
Mand
Re: Website Builder
I've raised this to our portal team, as the description of the page could do with an update.
In the meantime, we recommend NVU.
Peter_Vaughan
Re: Website Builder
It needs more than an update, it needs removing completely until you decide what to do with it. It has been in the current state for months so there is no reason for it to remain.
billbo
Re: Website Builder
Although there are other priorities (email  Shocked ) it really is time that this was fixed.  Roll_eyes
