Webcounter no support
- Everything else
- Webcounter no support
04-01-2010 11:22 PM
I have a webcounter on my site and have for many years it had reached 251000 it suddenly dropped to 0 so I raised a tick ID: 31297187 this has happend in the past and a ticket gets it fixed as all that is required is for someone to reset a txt file. Support claim its not down to them as its a coding issue. I have told them the code hasnot changed and has worked fine since 2002. I simple want them to put back may counter to 251000 plus its current value which can be seen http://www.mwright.plus.com/counter.html.
This has been going on since 21st December why can they do such a simple task? Most other webcounters on the net the user can reset from a script. The effect of the counter change means advertisers wont like a low count or I have to spend a lot of time re writing all my webpages as all my sites us the same counter
Message 1 of 4
(1,045 Views)
3 REPLIES 3
Re: Webcounter no support
05-01-2010 12:53 AM
Counters dropping to zero can be caused by two visits to the site simultaneously with the file not access-locked during update. The file might transiently not exist when the second visit is counted, and often this results in the counter being reset to 1.
That problem would be regarded as a coding issue as stated by Support. Can't you reset the file yourself?
David
Message 2 of 4
(228 Views)
05-01-2010 10:25 AM
Not if it's one of the Plusnet supplied counters on homepages!
Message 3 of 4
(228 Views)
12-01-2010 4:00 PM
I've fixed this now, I'll make sure the support guys know that this is supported, it's one of our more obscure features to be honest.
Message 4 of 4
(228 Views)
