Web design help
- Everything else
- Re: Web design help
Web design help
15-01-2009 6:12 PM
Hi I have designed a website with dream weaver and inserted a left hand navigation bar. Looks fine on home page but as soon as I return to the homepage from another linked page the navigation bar always shows in duplicate. Im sure this is just a straightforward link problem but Im new to this and not sure what I would need to do to rectify this. Any help on this one?
Message 1 of 4
(1,266 Views)
3 REPLIES 3
Re: Web design help
15-01-2009 6:37 PM
Sounds like the site is using frames and is loading the homepage (including the menu bars) into the main frame.
Its a while since I used DW but I think that there is a code option that prevents the site from being loaded into a frame window.
let me check it out for you
Message 2 of 4
(563 Views)
Re: Web design help
20-01-2009 2:05 PM
I guess the issue has been resolved, but what the hell.
CG, you might want to look into adding the menu bar as a server side include. This would simple "call in" the menu file into the desired area or table for instance. Like frames, it will mean you just have the one file to edit and they're easy to implement in DW.
Message 3 of 4
(563 Views)
Re: Web design help
24-01-2009 10:48 AM
Thanks for your help. Hopefully we'll now solve the problem.
Message 4 of 4
(563 Views)
