Web Publishing Problem
- Everything else
- Re: Web Publishing Problem
01-02-2011 1:12 PM
Hi
I have designed website in FrontPage and tried publishing using PlusNet but have problems - the text has published but not background and pictures. Website address is www.bloye.co.uk if you have time to look at problem. Advice much appreciated, thanks Jayne
Message 1 of 6
(1,206 Views)
5 REPLIES 5
01-02-2011 1:44 PM
Could be wrong but I don't think Plusnet supports Frontpage any more.
Message 2 of 6
(513 Views)
01-02-2011 1:52 PM
The site is on homepages and providing no Frontpage extensions are used that shouldn't be a problem.
Have you looked to check if and where the images have uploaded? For example it's expecting the top left image to be in /_derived/index.htm_cmp_expeditn010_bnr.gif
Message 3 of 6
(513 Views)
01-02-2011 3:05 PM
Hi
I also use FP uploaded to the homepages. Did you use the upload button within FP? If not, you may not have uploaded all of the subfolders you need. My site is at www.chelmsfordsongsters.org.uk and as you see, it looks fine.
Message 4 of 6
(513 Views)
06-02-2011 9:57 PM
I am not sure how the links to the images are ending up as they are but they are wrong and will not work:
http://www.jab12.plus.com/_derived/news.htm_cmp_expeditn010_vbtn_a.gif
In fact, it looks like folder /_derived/ does not even exist on the server.
What do the links to the images look like on your local preview?
Message 5 of 6
(513 Views)
07-02-2011 2:12 AM
That /_derived/ folder and the image file names look peculiar but appear to be similar to those on the Songsters pages so I assume that is the naming style FP uses.
The only links on your site that appear to work are those to pages in the home directory. Have any other folders been uploaded? There isn't something like an "include subfolders" tick box is there?
David
David
David
Message 6 of 6
(513 Views)
- Everything else
