Visitor photo upload
- Everything else
- Visitor photo upload
12-11-2007 11:29 PM
Re: Visitor photo upload
13-11-2007 5:55 AM
and
http://ezwebalbum.viehland.org/purchase.shtml
Regards Andy
13-11-2007 9:27 AM
14-11-2007 11:23 PM
Quote from: Peter Use coppermine.
Hi I have the neccesary files and have been reading the installation It say install to my webserver is this www or the cgi one pls. It looks like www but thought i would ask. I have also downloaded imagemagick although not sure as yet what to do with it but will work it out LOL
Regs Andy
14-11-2007 11:41 PM
Imagemagick is already running on ccgi, so no need to install it (Version: ImageMagick 6.0.6 02/11/07 Q16).
15-11-2007 4:57 AM
15-11-2007 9:21 AM
username@cshell1 username $ tar xvzf cpg<press the tab key, then enter>
to unpack it on the serve,rall to no avail what am i doing wrong or missing.
Can i not just d/l the zip and unpack it then upload it?
Sorry to be a pain Regs Andy
15-11-2007 9:33 AM
On the coppermine download page http://sourceforge.net/project/showfiles.php?group_id=89658 take the zip-file: "cpg1414.zip".
Upload into home of ccgi - not into the directory /cgi-bin. Into cgi-bin go only perl programms.
Unpack it with the command:
username@cshell1 username $ unzip cpg1414.zip
(Alternatively you can unzip it on your computer, but the upload will take ages and if the connection breaks you don't know what folders and what files are now missing).
From there follow the tutorial.
(Question to all: how does one unpack 7z-files on ccgi, what is the command?)
15-11-2007 11:13 PM
15-11-2007 11:46 PM
15-11-2007 11:58 PM
I am not sure, but I don't think a path is required for ImageMagick? If certain commands are input, it will just execute these. To check it, input on the command line:
<yourplusnetusername>@cshell01:~$ convert -version
Be so kind to write, when all works
16-11-2007 12:02 AM
Quote from: OshB5 Log in with the admin username and password you set up during install,..
Can't help on that, sorry. I did an install ages ago. Just follow the PlusNet guide by the word.
If you didn't write up the username and password - that's it. Possibly it is written in a configuration file, which you could change. Just ask in a coppermine forum.
Another option is to install it again - exercising the routine...
17-11-2007 8:24 AM
17-11-2007 9:26 AM
Regs Andy
17-11-2007 11:57 AM
Best is probably to open a new thread and to ask how to do it.
