Virgin and Plusnet In same house?
- Everything else
- Virgin and Plusnet In same house?
17-05-2023 10:22 PM
Message 1 of 3
(2,043 Views)
2 REPLIES 2
Re: Virgin and Plusnet In same house?
18-05-2023 8:15 AM
Moderators Note
This topic has been moved from Broadband to Everything Else
Message 2 of 3
(1,982 Views)
20-05-2023 8:39 AM
@shaelutah - It's possible it just needs to be made clear by you, the new provider, then to Openreach that they need to install a new line if virgin are using the Openreach network as they will normally just transfer services from one provider to another. If virgin are using their own cable in your area rather than the BT infrastructure, they are completely separate.
- Everything else
