VPN stopped working
- Everything else
- VPN stopped working
VPN stopped working
26-11-2018 3:38 PM
I connect via a VPN to a company I work with and it has stopped working - which is quite frustrating. I am using L2TP and I have powered everything off -- fibre modem and my PC to no avail. I use this VPN successfully most days. If I use my phone I can set up a VPN and it doesn't work whilst I am connected to my broadband wireless. If I disconnect and use a 3G connection it connects immediately. My current IP is a 51.9.x.x and the VPN I am trying to connect to is a 213.78.x.x IP.
Any suggestions?
Re: VPN stopped working
30-11-2018 12:15 PM
Hi @RobChafer, sorry to hear you're experiencing issues connecting to a VPN while using the broadband connection we're providing.
If you're still experiencing problems with this now, could you drop me a PM with the name of the VPN client you're using and the business you're trying to connect to so I can discuss this with a colleague on our Networks team to look in this further.
Thanks.
30-11-2018 12:31 PM
It magically started working again the next day!
30-11-2018 12:39 PM - edited 30-11-2018 12:39 PM
30-11-2018 1:00 PM
@RobChafer has your IP address changed by any chance ?
30-11-2018 1:49 PM
@MisterW, not since the 19th. That's where my mind went with it straight away too.
30-11-2018 1:58 PM
30-11-2018 2:36 PM
I was going to power off the router for half an hour to see if it changed the IP but in the end I didn't need to.
How often are IPs changed?
30-11-2018 11:34 PM
Normally only if the connection is dropped, eg by restarting the router. Even then the "new" IP can be the same as the old one (or at best in the same range) if down time is short.
When an IP from a different range is desired it is usually recommended to try disconnecting for 65 minutes.
