VPN stopped working
RobChafer
VPN stopped working
I connect via a VPN to a company I work with and it has stopped working - which is quite frustrating.  I am using L2TP and I have powered everything off -- fibre modem and my PC to no avail. I use this VPN successfully most days.  If I use my phone I can set up a VPN and it doesn't work whilst I am connected to my broadband wireless. If I disconnect and use a 3G connection it connects immediately. My current IP is a 51.9.x.x and the VPN I am trying to connect to is a 213.78.x.x IP.
Any suggestions?
Tags (1)
8 REPLIES 8
HarryB
Fixes: 256
Re: VPN stopped working
Hi @RobChafer, sorry to hear you're experiencing issues connecting to a VPN while using the broadband connection we're providing.
If you're still experiencing problems with this now, could you drop me a PM with the name of the VPN client you're using and the business you're trying to connect to so I can discuss this with a colleague on our Networks team to look in this further.
Thanks.
 Harry Beesley
RobChafer
It magically started working again the next day!
HarryB
Fixes: 256
Glad to hear that Rob, thanks for letting us know Thumbs_Up
 Harry Beesley
Fixes: 395
@RobChafer has your IP address changed by any chance ?
HarryB
Fixes: 256
@MisterW, not since the 19th. That's where my mind went with it straight away too.
 Harry Beesley
Fixes: 395
Thanks @HarryB , I would have put money on it being an IP change that started it working again.
RobChafer
I was going to power off the router for half an hour to see if it changed the IP but in the end I didn't need to.
How often are IPs changed?
spraxyt
Resting Legend
Fixes: 75
Normally only if the connection is dropped, eg by restarting the router. Even then the "new" IP can be the same as the old one (or at best in the same range) if down time is short.
When an IP from a different range is desired it is usually recommended to try disconnecting for 65 minutes.
David
