VPN not working
Mystified
VPN not working
I am trying to connect my work laptop which has a VPN on it. It establishes a connection but immediately drops out and block access to the internet. The cutosmer services team said they do not support VPN and were quite rude. They have also failed to respond to my request to speak to a manager. Can any one help with the VPN connection
10 REPLIES 10
Fixes: 1,483
Re: VPN not working
Moderators Note
This topic has been moved from Tech Help to Everything Else
RandallFlagg
Fixes: 75
Re: VPN not working
Hi @Mystified
Thanks for getting in touch - I'm sorry that your manager call back hasn't taken place yet - I've chased this for you accordingly.
In terms of the VPN issue, I'm afraid the advice you've been given is correct - we can only guarantee connectivity via a direct connection to the BT Exchange using the IP address we allocate to you - any other software that sits in the middle of this may potentially affect connectivity and we're unable to support such software as we have no visibility or knowledge of how it interacts with our connection.
That being said, this community is full of incredible members who have a broad spectrum of experience and knowledge and I'm sure someone here will be able to point you in the right direction.
Best wishes
Dave
Fixes: 1,483
Re: VPN not working
Which VPN client is it?
Mystified
Re: VPN not working
I believe its CISCO Anyconnect
Fixes: 1,483
Re: VPN not working
I use that currently, haven't had any issues - I have a static IP address though.
You could try adding that for a one off cost of £5 and see if that helps.
Mystified
Re: VPN not working
No thank you, I have seen other threads on here where a static IP address was suggested but it didn't fix the problem so I don't want to waste my money. My router is 7 years old so I am hoping that may be the problem. I have ordered a new one so I will see if tha.t will fix the problem
Fixes: 1,483
Re: VPN not working
Hope it sorts it for you.
7up
Fixes: 17
Re: VPN not working
I had similar tales of woe when setting up my vpn. Turned out i needed two ports open on the router. Can't remember the exact details now but you might want to look into that.
corringham
Seasoned Champion
Fixes: 16
Re: VPN not working
You shouldn't need any ports open to run a VPN client (i.e. outgoing connection), open ports should only be needed if you want to run a VPN server (i.e. for incoming connections).
I run both outgoing and incoming VPNs, using AnyConnect, OpenConnect and my router's builtin SSL VPN.  Plusnet don't block VPNs, but they don't offer support for them either.
Fixes: 160
Re: VPN not working
Could this be a matter of the PC’s AV (software firewall) blocking the outbound connections?
