Using SEO URL's in Joomla 1.5.10
- Everything else
- Using SEO URL's in Joomla 1.5.10
01-05-2009 5:36 PM
Im trying to use the SEO settings in Joomla to rewite my website urls. Do the plusnet servers have mod_rewrite enabled on them? Has anyone else got this working on their Joomla sites on cgi webspace? (I have changed the htaccess.txt file to .htaccess in the root directory). If I enable the setting to make the urls search engine friendly I get Internal server errors whenever I try to move to another page on my site (only the homepage works).
Message 1 of 4
(1,288 Views)
3 REPLIES 3
Re: Using SEO URL's in Joomla 1.5.10
02-05-2009 9:27 PM
I don't have Joomla running on cgi anymore so I can't do any test but there is this section in the .htaccess file that you may need to change to get it to work properly:
Not sure if this will help or not.
Quote # Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root)
# RewriteBase /
Message 2 of 4
(257 Views)
04-05-2009 2:26 PM
Ive tried this and I still get error messages like "Not Found The requested URL /cgi-bin2/cgiwrap/index.php/xbox-360 was not found on this server." Anyone got any other ideas?
Message 3 of 4
(257 Views)
24-10-2009 1:45 PM
Did you get this solved or has anyone else got any suggestions as I'm getting the same problem when I turn on Search Engine Friendly URLs. Works perfectly with them off, but as I'm new to this I really don't know where to look at settings.
Message 4 of 4
(257 Views)
- Everything else
