Using Filezilla with secure plusnet webpages
simonc2
I just discovered from this forum that my plusnet webspace (created when I had a business broadband) can be accessed securely at https://homepages.plus.net/***myaccountname***/
Is there a way I can use Filezilla to send files securely to this secure area? At the moment if I try to connect to the host ftp.plus.net it gives dire warnings that my username and password will be sent in clear over the internet, which is not desirable!
I've just found a plusnet help page which states "Your webspace uses the server ftp.plus.net, which supports SSL." Does this mean the Filezilla error "Insecure server, it does not support FTP over TLS" is incorrect?
5 REPLIES 5
bobpullen
Fixes: 314
Re: Using Filezilla with secure plusnet webpages
The FTP server doesn't support SSL/TLS. Where is the web page you've referred to?
simonc2
Here is the link
https://www.plus.net/help/broadband/ssl-security-guide/
Here is a screenshot:
bobpullen
Fixes: 314
Thanks. Will get that fixed (ref: DFD-3132).
simonc2
Glad to help, but is the upshot that there is no secure way I can update files on my webspace?
bobpullen
Fixes: 314
Sadly, yes. I can't see the situation changing any time soon Sad
