Using Cron to unzip files
- Everything else
- Using Cron to unzip files
13-02-2009 10:40 AM
I have just started using my Payh webspace and uploaded PhpGedView.zip to my httpdocs folder but cannot get unzip to work.
After studying both Cron tutorials I created the following command:
'/usr/bin/unzip -a httpdocs/PhpGedView.zip httpdocs/ > httpdocs/pgvunzip-log 2>&1'
which produces the log file containing:
'Archive: httpdocs/PhpGedView.zip caution: filename not matched: httpdocs/'.
Searching the web finds several instances of 'filename not matched' but they all relate to unzipping multiple files using wildcards.
Do I need a longer path name to the file location?
David
David
Message 1 of 3
(1,303 Views)
2 REPLIES 2
Re: Using Cron to unzip files
13-02-2009 7:48 PM
I think the problem is that you've asked for directory httpdocs to be extracted from the ZIP file and, of course, it isn't in there.
To fix this you need to include "-d" after the ZIP archive specifier as in
'/usr/bin/unzip -a httpdocs/PhpGedView.zip -d httpdocs/ > httpdocs/pgvunzip-log 2>&1'
to tell unzip that what follows is the location to which files are to be extracted. Since the file list is omitted all files in the archive will be extracted.
David too
David too
David
Message 2 of 3
(257 Views)
13-02-2009 10:41 PM
Thanks David that was it.
It inflated to over 4000 files in minutes.
It would have taken me days doing it manually.
Thanks again
David
Thanks again
David
Message 3 of 3
(257 Views)
- Everything else
