Usenet
DreamVB
Usenet
Hi I am looking for any free usenet server does plusnet support usenet I am doing a cource on how the internet started and was readint about use net and like to give it a try I also been looking at online BBS boards using tell net and now want to try usenet I found a few free servers but not very good most you have to pay for. any info be handy thanks.
3 REPLIES 3
bobpullen
Fixes: 314
Re: Usenet
From a Plusnet connection, you can use news.plus.net on port 119 (no authentication).
The server does not carry binaries though.
If you need access away from your Plusnet connection, try Eternal September - https://www.eternal-september.org/
Fixes: 1,480
Re: Usenet
Moderators Note
This topic has been moved from Chat to Everything Else
DreamVB
Re: Usenet
Thanks I try the plusnet one
Thank you agian for the quick reply
