Uploading to my website
- Everything else
- Uploading to my website
26-08-2007 5:31 PM
Hi, I am having problems uploading to my website with Dreamweaver. Most mornings I can upload files ok even though it does sometimes take ages to connect, but all afternoons and evenings I can’t connect at all! I have tried on a friends PC (different ISP) and it works fine and I know the details I have put into remote info are correct because I can connect mornings. So if anyone knows why this is happening please help me.
Message 1 of 2
(1,892 Views)
1 REPLY 1
Re: Uploading to my website
26-08-2007 10:53 PM
Heavy downloads or P2P can effect it as well when I had the problem I used 212.159.9.131 to connect in stead of the name and it worked for me.
Does it take a long time to connect or does it connect ok and then take a long time to upload?
Message 2 of 2
(530 Views)
- Everything else
