Upload Issues (F9 Customer)
zombies
I can happily connect via DOS/CuteFTP to the homepages server.
Regardless of what I do (rename a folder/file or upload) it ALWAYS gives me 'Access Denied'.
I have properly logged in with my F9 username and password to 'homepages.force9.net'.
Could someone check my webspace to find out why I cannot upload to it please?
Thanks.
K. Hawkes
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: Upload Issues (F9 Customer)
Are you trying to do this to folders <i>inside</i> the htdocs directory? If you are trying to create folders outside there then you'll get that error.
zombies
Yeah - it had been a long day, I was however trying to upload from my workplace - rather than my home.
So this kinda explains why I couldn't upload - not sure if it's meant to work that way, but as soon as I got home and did it, it was fine.
Thanks Smiley
K. Hawkes
