Upload Issues (F9 Customer)
- Everything else
- Re: Upload Issues (F9 Customer)
07-08-2008 2:54 PM
I can happily connect via DOS/CuteFTP to the homepages server.
Regardless of what I do (rename a folder/file or upload) it ALWAYS gives me 'Access Denied'.
I have properly logged in with my F9 username and password to 'homepages.force9.net'.
Could someone check my webspace to find out why I cannot upload to it please?
Thanks.
K. Hawkes
Thanks.
K. Hawkes
Message 1 of 3
(1,337 Views)
2 REPLIES 2
07-08-2008 2:59 PM
Are you trying to do this to folders <i>inside</i> the htdocs directory? If you are trying to create folders outside there then you'll get that error.
Message 2 of 3
(333 Views)
13-08-2008 9:01 AM
Yeah - it had been a long day, I was however trying to upload from my workplace - rather than my home.
So this kinda explains why I couldn't upload - not sure if it's meant to work that way, but as soon as I got home and did it, it was fine.
K. Hawkes
K. Hawkes
Message 3 of 3
(333 Views)
- Everything else
