Unable to log into member services
RPMozley
Seasoned Pro
Fixes: 16
Re: Unable to log into member services
This is most likely due to a bad IP reputation. Next time you connected you probably got a different IP.
That's RPM to you!!
Mav
Fixes: 518
I just thought I'd check using Windscribe both using a non and UK IP and my log in request failed both times with the password not being recognised.
Forum Moderator and Customer
Fixes: 334
Same response here, @Mav  - although I use Nord VPN.
Fixes: 124
Well that's odd I have logged on with no issues using windscribe with a UK server 84.17.50.194 and US server 68.235.33.136 with no issues.
I am using the Windscribe app rather than a browser plugin
HTH
Edit: if required I could install windscribe on one of my reference linux system rather than using windows
Mav
Fixes: 518
My above tests were using the Firefox browser plugin .
I just tried using the app with the same result. All tests done on my PC.
