Unable to add CNAME record containing underscore
starfry
I have a hosted domain using the Plusnet namesevers and I need to add a cname record to it that contains an underscore. This is a valid value however Plusnet portal disagrees "Error: Only the characters . - a-z 0-9 are allowed in the left field".
Is there any way around this or will I have to migrate my nameserver to one that works properly?
4 REPLIES 4
7up
Fixes: 17
Re: Unable to add CNAME record containing underscore
@bobpullen should be able to help.
Fixes: 1,483
Moderators Note
This topic has been moved from Tech Help to Everything Else
adam945
Fixes: 113
Hi @starfry
Correct, you'd be unable to add any other characters to the CNAME unfortunately.
-Adam - Plusnet  Leeds
 Adam
 Plusnet Help Team - Leeds
starfry
Is this a bug or a design decision?
Either way, can this be fixed? And while you're at it... proper support for tags like PTR and TXT.
