Unable to access wp-admin after upgrade to WordPress 3.0
- Everything else
- Unable to access wp-admin after upgrade to WordPre...
26-07-2010 9:51 PM
I hope someone can help me here: after finally sorting out my botched WordPress 3.0 install (back-ups are great), I'm now unable to log in to wp-admin; it wants to redirect me to wp-admin/kingscott//blahblahblah
Fortunately, my site is still up so my three readers won't be disappointed, but it's odd I can't get in - any suggestions? I have all my PHP files (all as in all, in wp-admin, wp-content, etc.) set to 755, is the redirect to my username's folder related to folder permissions?
Thanks for any advice,
Mike K.
Re: Unable to access wp-admin after upgrade to WordPress 3.0
27-07-2010 10:47 AM
Gabe
27-07-2010 5:30 PM
"URL requested (/wordpress/wp-admin/install.php) not found"
Any ideas?
28-07-2010 6:56 AM
Hello, thanks for the reply. I read the FAQ and also adjusted my folder permissions, but I'm not sure which script you mean in the FAQ?
Also, it appears my forms are working (no POST problems) as I can leave comments on my blog posts...
Thank you,
Mike K.
28-07-2010 8:43 AM
If that's not the answer, it could be an upload glitch. Was this a fresh install rather than an upgrade?
Gabe
02-08-2010 8:29 PM
It was an upgrade, but I botched it by removing the wp-content folder. I realised my mistake and copied it back, but things are a bit borked still. I will try the script, look at what folders need 777 access and set that to 750 as suggested, and see where I get to.
It's odd that the wp-admin logon is redirecting me back to a URL my user name appended to it...
Thank you,
Mike K.
03-08-2010 11:17 PM
Mike K.
03-08-2010 11:34 PM
04-08-2010 10:41 PM
http://www.mkingscott.co.uk/wp-login.php?redirect_to=http%3A%2F%2Fwww.mkingscott.co.uk%2F%7Ekingscot...
and I believe the %7E is the tilde...
What's the thought?
Thank you,
Mike K.
05-08-2010 1:23 PM
Just to check, what happens if you delete everything from the ? onwards, so you're just left with http://www.mkingscott.co.uk/wp-login.php (or follow this link), then delete any cookies you have from that site, then refresh the page, then enter your login details?
Gabe
- Everything else
