Unable to access William Hill
Richie
For the last couple of days I've been unable to access William Hill website or apps. Works fine when I connect via Three mobile. Any ideas? Thanks
7 REPLIES 7
Fixes: 466
Re: Unable to access William Hill
@Richie
It works for me. Have you got Safeguard or some other filter software installed on your computer?
Richie
31753BBF-E7BE-404D-9CFC-858DB0BD99B4.jpegNo, worked fine up until a few days ago, and I haven't changed any settings. Says "403 Error - request blocked" now...
Fixes: 466
@Richie
Have you tried using a different Internet browser on your computer?
Richie
Yes, all access from Plusnet to website and apps is blocked... Different browsers and devices. Three mobile has normal access.
Fixes: 466
@Richie
My suspicion is that Safeguard has been enabled on your Plusnet account with gambling sites being barred. If you can select your own D S server on your device then over ride Plusnet’s by using say the Google DNS servers on 8.8.8.8 and 8.8.4.4.
Alternatively log into your router and see which DNS servers are enabled and/or your Plusnet account and check/modify your Safeguard settings.
Richie
Thanks Baldrick but unless Safeguard can be changed remotely by Plusnet then no settings have changed, and I don't really want to start messing with settings etc. My other gambling site, Coral, still works fine as before.
Richie
Tried again this morning, and access restored...!
