Unable to access Webspace with FP nor with CuteFTP
- Everything else
- Unable to access Webspace with FP nor with CuteFTP
09-02-2008 6:34 PM
I migrated to PlusNet, partly because of support for FrontPage extensions. I activated FrontExtensions about a week ago. However, when I try to upload my site with Front Page I get various error messages.
So in desperation I downloaded CuteFTP and still no progress. i.e.
CuteFTP - File – Connection Wizard – Host Address – ftp.plus.net – Site Name – ftp.plus.net – User Name – myusername – password – mypassword
Error message “The host validation failed. Check that the user name and password are correct. Press no to skip check.”
Any suggestions / help appreciated. Thanks
Message 1 of 6
(1,947 Views)
5 REPLIES 5
Re: Unable to access Webspace with FP nor with CuteFTP
09-02-2008 7:35 PM
If you must use Front Page to up lode to the Front Page Server, put in to Front Page:
For f9 http://fp.Username.f9.co.uk
For PlusNet http://fp.Username.plus.com
with your Username & Password from the portal.
Message 2 of 6
(448 Views)
10-02-2008 10:22 AM
Quote from: Midnight If you must use Front Page to up lode to the Front Page Server, put in to Front Page:
Thanks for the advice, but unfortunately it doesn't work. Maybe the webspace needs setting up in some way by plusnet?
Message 3 of 6
(448 Views)
10-02-2008 10:28 AM
There is an open problem with FP activation so I suggest you raise a ticket and ask if your account is affected by the problem. ALso state the problem you have with normal FTP access and get CS to reset the component.
Message 4 of 6
(448 Views)
11-02-2008 9:06 AM
I raised a problem last week on homepages access not activating correctly(49958), it's probably this causing the OPs problem.
I'll see if I can get this pushed through, in the meantime it's simple enough to fix on a single user basis by refreshing the component internally.
Message 5 of 6
(448 Views)
11-02-2008 5:59 PM
Thanks for messages. I am now able to upload my webpages using CuteFTP and they are displaying OK. However, I would prefer to use Front Page and also have the FP extensions in operation. Anyway, I have a current "My Question" on this, so hopefully I will have FP soon.
regards
Peter
regards
Peter
Message 6 of 6
(448 Views)
- Everything else
