Unable to access .CH govt sites
BadToro1
I'm unable to access .ch govt websites using plusnet fibre -
***this is not an issue using vpn or mobile phone connection or from work***
an example is:
admin.ch
162.23.130.190
Traceroute times out after 15 hops
gi101-befll15a-sge-ice1.inetbb.admin.ch
Please note that admin.ch is the equivalent of .gov.uk websites in the UK.
I've tested other .ch websites and there are no issues, example srf.ch (equivalent of bbc.co.uk).
Clearly there is a routing problem via plusnet, can this be looked at and fixed?
Thank you.
14 REPLIES 14
Legend
Fixes: 248
Re: Unable to access .CH govt sites
Welcome  to the forums, @BadToro1 . This won't help you, unfortunately, but I had no problem accessing the site you mention.
As a point of interest, can you post the traceroute you get, because it sounds like the problem is outside the Plusnet area, given where you fail.
BadToro1
hey @jab1 thanks for your message.
Unfortunately, i can confirm that using connections other than my plusnet fibre there are no issues.
I have no doubts this is not a plusnet-wide network issue, but certainly it is an issue with ip ranges in my area, otherwise i would not be able to explain why you would be able to connect.
At any rate, i will try and get a traceroute as soon as i can.
Legend
Fixes: 248
I seem to remember someone else having this problem quite a while back, but unfortunately can't find the thread to see if/how it was resolved, but I know it was.
Fixes: 1,482
Just another report of it working here on my PN connection.
BadToro1
Fixes: 1,482
It suggests that if you add static ip in the member center (£5 one off fee) then it *may* fix your problem, or may not.
Otherwise you'll have to wait for a PN staffer to come and offer some help, which given the current situation may be a while Sad
BadToro1
@dvorak i don't mind paying the £5 but it seems a gamble (i'd rather invest it in a lottery tkt lol),  i'd do if the tech support could check it worked...and that's not going to happen.
Marksfish
Seasoned Pro
Fixes: 4
Not working for me. I am on the 143.159.80 range of ip addresses. I just get a "took too long to respond" error.
BadToro1
I’m on 146.198.x.x
Legend
Fixes: 248
51.6.205.xx - totally different to the two above.
BadToro1
Plusnet staff any advice please?
BadToro1
Any acknowledgement from Plusnet staff? Things are slowly going gave to normal I’m hoping someone picks it up and provides a solution to an annoying problem.
bobpullen
Fixes: 315
A traceroute from a non-working connection would be a good start. Based on one of your opening posts, the traffic is hitting the admin.ch domain so there's every chance the blocking/issue could be at the remote side. Looks likely that it's something to do with certain IP ranges we issue mind you.
I suspect a static IP would fix it. Be good to get to the bottom of things though.
BadToro1
If there was any guarantee that a static IP would fix it I’d go for it
Unfortunately it sounds like a gamble as I can’t choose my IP address, thus bit pointless spending any money.
