.UK Domains
- Everything else
- .UK Domains
.UK Domains
10-06-2014 6:29 PM
Re: .UK Domains
10-06-2014 8:29 PM
Re: .UK Domains
11-06-2014 12:27 AM
Re: .UK Domains
11-06-2014 7:29 PM
Re: .UK Domains
12-06-2014 1:27 PM
Re: .UK Domains
12-06-2014 3:38 PM
[quote author="Nominet"]You do not have to have the same registrar for a .UK domain name. The following details needs however do need to match:
- Registered name
- 1st line of the address
- Country code
- Postcode
- Email address.
If you choose to register the .UK domain name through a different registrar to your co.uk domain, you will receive an authentication email from Nominet requesting that you confirm you wish to register the domain.
Re: .UK Domains
20-07-2014 11:07 AM
Why aren't PN/JTN handling .uk registrations? You handle several other TLDs
Re: .UK Domains
21-07-2014 10:06 AM
Quote from: SteveA Why aren't PN/JTN handling .uk registrations? You handle several other TLDs
Put simply, because it would require development work that is probably better invested elsewhere at the moment. It's also fairly difficult to justify the cost. I doubt we'd want to delve into the legacy code-base that is the Plusnet Domain Control System and the return we'd get from implementing it for JTN would be slim.
Having said that, I'm basing a lot of that on assumption. We'll try and look into it properly at some point, I wouldn't hold your breath though. It's definitely going to be quicker to register via an alternative registrar.
Personal recommendation.
Re: .UK Domains
19-08-2014 10:46 PM
Re: .UK Domains
19-08-2014 10:48 PM
