Trouble installing Joomla 1.6
- Everything else
- Trouble installing Joomla 1.6
07-11-2011 12:36 AM
Hello,
Has anyone managed to install and run Joomla 1.6 on the Plusnet CCGI space? The Joomla installation script gives me a message saying it requires MySQL 5.0.4 or higher, and Plusnet only run 4.1.11 and have no plans to upgrade anytime soon.
I was wondering if there is a work-around?
Other posters on this forum seem to be using Joomla. Are you running v1.6?
Thanks for your help.
Message 1 of 4
(876 Views)
3 REPLIES 3
Re: Trouble installing Joomla 1.6
07-11-2011 12:06 PM
I think the only way to get Joomla working in Plusnet ccgi space is to install the latest 1.5.x version which works with MySQL v 4.1.
Though Plusnet have looked at upgrading MySQL to version 5.x I can't see that happening until well into next year. Consultation in this thread on how such an upgrade should be handled attracted little feedback.
David
Message 2 of 4
(206 Views)
08-11-2011 12:54 AM
Thanks for that Spraxyt. As I suspected.
I'll give v1.5 a try.
SwearRoot
SwearRoot
Message 3 of 4
(206 Views)
09-11-2011 9:18 AM
You cannot run 1.6 on either the old and creaky ccgi or on PAYH 1.5 is as far as you can go at the moment.
Message 4 of 4
(206 Views)
- Everything else
