Transfer my domain
dno_xyz
Transfer my domain
Hello I would like to transfer my .co.uk domain out of Plusnet to a new provider.  Can someone at Plusnet change my IPS TAG
5 REPLIES 5
Penny
Fixes: 9
Re: Transfer my domain
Hi @dno_xyz , welcome to the forums.
The support guys will need your domain name - hopefully one of them will send you a PM to ask for that, or if you have no objections to posting it here, they'd probably be able to action the transfer more swiftly.
They'd also need to know the new IPSTAG.
From recall I believe the process of making the change takes somewhere around three days (NetOps?) after one of the support guys has input the request.
You should be able to check the ongoing progress via https://www.domaindiagnosis.com/
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
dno_xyz
Penny thank you for reply and suggesting via https://www.domaindiagnosis.com/
If possible could Plusnet Support please send me a PM or open a support ticket for me so I can send the details of my .co.uk Domain and new IPSTAG
Thankyou
Tags (1)
willcutforth
Fixes: 113
@dno_xyz Just sending you a PM now.
 Will Cutforth
danielgmartin
Hello @willcutforth I did not receive your PM can you send it again. Thanks
SammyM
Fixes: 101
Hiya, I have sent you another Smiley
 Sammy M - Sheffield Team
