Transfer freenetname / madasfish domain
FIXED- Subscribe to RSS Feed
- Everything else
- Transfer freenetname / madasfish domain
23-06-2023 3:57 PM
Seeing previous posts on the subject, I think I will need some help by PN to get my old freenetname/madasafish domain transferred out.
Customer service via telephone didn't have a clue what I was talking about and pointed me towards here.
So hopefully someone can be of some assistance.
Many thanks in advance.
Tetsuo
Fixed! Go to the fix.
Re: Transfer freenetname / madasfish domain
23-06-2023 4:05 PM
Moderators Note
This topic has been moved from Email to Everything Else
23-06-2023 4:17 PM
Have you identified a new registrar / hosting?
If yes, have you started the process? You need to do that first.
There are differing thoughts on the sequence to do this. Personally I would do as much as possible to commission your new email provider's services before moving the domain's registration and DNS / name server. That should allow you to move old emails over before losing access to the MAAF service / content.
If this is a .uk domain, the process is simple - you just ask Plusnet to change the TAGS code to that of the new registrar. If it is a .com domain, you'll need to request am EPP code.
See How to transfer .co.uk and .com domain names – Our top 5 tips (unionroom.com)
24-06-2023 3:53 PM
Many thanks Townman,
Have taken onboard your suggestions and signed up with a new hosting provider.
As you have pointed out, I now need to let PN know the new hosting provider's TAG code and obviously the domain name to be transferred. How can I do this or "raise a ticket" as previous postings have eluded to?
24-06-2023 4:01 PM
You cannot raise a ticket. Post on the Everything Else board - a staff member will pick that up and raise a ticket for you...
25-06-2023 6:08 PM
I cannot email to gmail account holders. My domain is Freenetname I think I will need some help by PN to get my old freenetname domain transferred out. Yet, I do not want to change my address [email protected]. Would transferring out solve my problem?
Kind regards
Franco
25-06-2023 6:25 PM
Hi Franco,
Your HOST provider is freenetname.co.uk - part of the Mad As A Fish (MAAF) portfolio. If you send email from [email protected] your emails should get through to Gmail, because there is a SPF configuration for that domain name.
MAAF does not provide a facility for HOSTED domain names to set a SPF record, so if you want to to send from @yourdomain.co.uk you will need to move the domain and hosting to another email hosting service. Given that you do use your own domain for emailing, you will not lose contact with parties to whom you have given email addresses referencing your own domain name.
If you have used [email protected] ... that would be a different matter.
Your first step is to identify an email hosting provider of your choice and then initiate the service transfer. You will need to request a TAGS change from Plusnet at the appropriate time.
You should still be able to access the MAAF mailbox after the migration.
@Gandalf - did I "miss" anything?
25-06-2023 7:09 PM
on
25-06-2023
8:25 PM
- last edited on
26-06-2023
4:27 PM
by
Dear Townman,
This is my account at freenentname:
email address: <redacted>
user name: <redacted>
Incoming server: mail.freenetname.co.uk
Outgoing server: smtpmail.freenetname.co.uk
Based on the above can you give me further instructions?
Many thanks
Franco
Moderator's Note: Personal information removed
26-06-2023 3:32 PM
Hi Franco,
Not sure what you are seeking here beyond "Your first step is to identify an email hosting provider of your choice and then initiate the service transfer. You will need to request a TAGS change from Plusnet at the appropriate time."
That information relates to your current hosting set up with MAAF (Plusnet). You probably need to find a new provider and initiate the transfer of your domain name to address Gmail's belligerence.
26-06-2023 10:03 PM
Dear Townman,
Thanks for your reply. Can you recommend an email hosting provider?
Kind regards
Franco
27-06-2023 11:19 AM - edited 27-06-2023 11:26 AM
Franco,
Asking for a recommendation is a big ask, for such needs experience of any provider one might recommend and potentially has comebacks if the recommendations do not fit your needs.
There are a vast array of providers out there (do a Google search) offering very little to as much as you can 'eat' from free to costing an arm and two legs. YOU need to consider what do YOU need ...
- Email
- How many mailboxes
- Aliases
- Catchall
- Auto responses
- Email forwarding (with SRS)
- Storage allowance
- Do you want the service to support contacts and calendars (as well as email)
- Website
- Environment - .php / .asp
- Database
- Web development tools - WordPress / Joomla (etc)
- Bandwidth
- Support availability and capability
Some of the above you might get for free by moving to Outlook.com or Gmail.com (including other data mining providers) - however I am not up to date with their domain name hosting offerings ... and have no insight as to how they facilitate multiple mailboxes on the same domain name ... as fundamentally their free services are single user products.
Paid for services range from ££ per mailbox per month, through to unlimited domains, unlimited mailboxes and unlimited addresses (along with a lot of bells and whistles) for just £ per month.
Personally I have used lcn.com who have excellent support but are not the cheapest (and by no means the most expensive). Mythic Beasts - Mythic Beasts (mythic-beasts.com) have some great packages from £2 pcm which will do all which your existing Plusnet / MAAF service will do ... and more besides. I have no direct experience of this provider, though they will probably be my preferred "target" for migrating my acquired business services - the current provider wants £200 pa for providing far less.
There are other providers.
30-06-2023 4:22 PM
Many thanks @willcutforth . Domain transferred and live on new provider! No more "gmail" bounce back!
Also thumbs up @Townman for highlighting my issue!
Keep up the good work guys!
30-06-2023 7:57 PM
To which new provider did you transfer your Madasafish email? Did you keep the same email address? Is there a monthly fee?
Franco
02-07-2023 5:41 PM
Can I ask Plusnet to be my new domain host for my Freenetname account? Would this transfer solve the problem?
- Everything else
