Transfer domain away from Plusnet
Brics
Hi
I have a legacy Force 9 domain that I want to transfer away from Plusnet to IONOS. I have been advised that I need to request that someone changes the IPS TAG from "FORCE9" to "IONOS".
From what I can see the only way to request this is to post here and wait for someone to open a support ticket, so if someone could do so I would be grateful.
4 REPLIES 4
MatthewWheeler
Fixes: 503
Re: Transfer domain away from Plusnet
Hi @Brics
I've raised that ticket for you now.
If you can respond to it I can get that underway for you
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
Brics
Thank you @MatthewWheeler for the lightning response!
I have updated the ticket as requested.
MatthewWheeler
Fixes: 503
Perfect thanks for that.
I've raised that to the right team and we'll get that done as soon as possible
 Matthew Wheeler
rflitcroft
It's not the only way, but it is probably the easiest and cheapest.
The alternative is to use the Nominet services website to change the IPS tag yourself and part with £12 for the privilege.
