Transfer a domain name out of plusnet request
Staedler
Hi
I'd like to transfer one of my domain names to GoDaddy. I believe I need an Auth or EPP code and this is where I might get help
Many thanks
Colin
3 REPLIES 3
Fixes: 526
Re: Transfer a domain name out of plusnet request
You only need an EPP code if it's a non-uk domain. Otherwise you just need the IPSTAG changed to the new registrar.
Either way , here is the place to request it. A staff member will be along in due course and will either raise a ticket or a PM go request the relevant information
Staedler
Thank you for the speedy response. I'll look out for the post
willcutforth
Fixes: 113
@Staedler sent you a text to reply to.
 Will Cutforth
