Transfer Freenetname domains out
toolkit
Due to the recent Gmail issue I need to transfer out a couple of domains registered last century with freenetname.
Apparently I need them to be unlocked and get an authorisation code for my other provider - can someone pick that up and open a case for me?
Thanks.
4 REPLIES 4
Fixes: 580
Re: Transfer Freenetname domains out
Are they .uk domains ? in which case they don't need to be unlocked or need an EPP code. You just simply request that the IPSTAG is changed to that of the new registrar
toolkit
Thanks - yes .co.uk - going to Gandi.net so needs updating to "GANDI"
Fixes: 580
One of the Help team will be along shortly, they'll likely raise a 'ticket' to which you can reply confirming the domain names and IPSTAGs. They'll then raise the transfer request to Netops which will take 2 or 3 days
MatthewWheeler
Fixes: 503
Afternoon @toolkit
I'll drop you a PM shortly regarding this
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
