Total Noob, Please Help!
mrmarkus1981
Hi all!
I recently activated my webspace with plusnet. I can upload to my webspace and add pics and whatever, thats fine!
However, i purchased a domain from plusnet which is being hosted by them. How do i upload pics etc to this website, everytime i try it shows up on my webspace (i.e www,mrmarkus1981.plus.com) and nmot the domain i bought!
Any help is appreciated, or directions to an idiots guide is also cool!
Mark
21 REPLIES 21
Chris
Legend
Fixes: 169
Re: Total Noob, Please Help!
I'll made a change to the hosting directory set on your domain, this will take around 4 hours to complete.
You'd set it to /index.htm and as there wasn't a folder by that name, it was displaying blank.
mrmarkus1981
Still cant do this.
Every time i try and upload to either my webspace or the domain i bought, i get Error 550 : Access is Denied.
I have tried using Frontpage and ExpressionWeb.
Does anyone have a GOOD guide to the whole process (uploading via FTP)
Strat
Fixes: 565
If you use Firefox then FireFTP (a Firefox add-on) is very good for uploading to your webspace.
Jake
or if in Internet Explorer go to ftp://ftp.plus.net and use your normal Plusnet username and password for access. That should let you in fine and you can drag and drop files into your webspace.
mrmarkus1981
Ol have managed to take a few extra steps now and have a website running.
The problem now is that there are thumbnails missing. If you go to www.ellen-wilson.co.uk the to gallery, then pick a category. There are lots of pics missing, i have logged into ftp://ellen-wilson.co.uk and all the actual files are present, so they have uploaded correctly. They just dont show on the site.
If need be i am happy to give my username/password so someone with more knowledge can have a look and see what the problem might be. I uploaded the pics the same way as i did the others (the ones that work!) so i dont know where its gone wrong!
HELP....ANYONE?
(PICS ATTACHED)
HPsauce
Could the long messy file names be part of the problem?
mrmarkus1981
I dont know, do you think so?
pierre_pierre
the file name "%20£17..jpg">"  has two period in it this is a no no, I assume it goes through the rest of the picture names
zubel
It's likely to be related either to the presence of a ' in the name, or perhaps the £ sign.
It is good practice to shorten image names substantially.  Maybe have "silverstag.jpg"
B.
mrmarkus1981
I will rename the files and see how i get on, no doubt this will screw up all the links though?
mrmarkus1981
There are £ signs in the ones that work too though?
mrmarkus1981
I have taken the .. away from the jpg filename, still the same problem????
Mal08
Quote from: mrmarkus1981
still here though:
img src="Opal%20in%20bedrock%20set%20pendant..jpg"
[Edit : } Are you using Dreamweaver ? ]
mrmarkus1981
The picture you refer to actually is one that works? I have been to the site again and the .. is not present.
I am using Expression Web
