Topic Vanished?
Nessworthy
Topic Vanished?
Hiya, I started a topic over the weekend in  the Fibre Broadband forum, but since coming back to check I've noticed it has totally vanished Shocked
It doesn't even show in my account posts, has it been flagged or do posts need some sort of approval?
5 REPLIES 5
Alex
Fixes: 13
Re: Topic Vanished?
No - posts don't need approval, it is possible it may have been moved elsewhere if a moderator feels it should be in a better forum. The mods will only generally take action to help or if you're breaking the forum rules.
Did you check your post was successful and appeared when you made it?
Aspiring Hero
Fixes: 33
Re: Topic Vanished?
Might be caught in the spam folder and not yet cleared by a Mod
Fixes: 1,466
Re: Topic Vanished?
I’ve released it from the spam folder
Alex
Fixes: 13
Re: Topic Vanished?
Ah yes @bmc, didn't think of that. The OP should report it to them and request it to be released.
EDIT: Thanks @dvorak.
Nessworthy
Re: Topic Vanished?
Thanks! Guess it probably flagged it up from post length or something.
