Topic Vanished?
FIXED- Subscribe to RSS Feed
- Everything else
- Re: Topic Vanished?
05-02-2018 2:04 PM
Hiya, I started a topic over the weekend in the Fibre Broadband forum, but since coming back to check I've noticed it has totally vanished
It doesn't even show in my account posts, has it been flagged or do posts need some sort of approval?
Fixed! Go to the fix.
Re: Topic Vanished?
05-02-2018 2:08 PM
No - posts don't need approval, it is possible it may have been moved elsewhere if a moderator feels it should be in a better forum. The mods will only generally take action to help or if you're breaking the forum rules.
Did you check your post was successful and appeared when you made it?
Re: Topic Vanished?
05-02-2018 2:10 PM
Might be caught in the spam folder and not yet cleared by a Mod
05-02-2018 2:11 PM
Re: Topic Vanished?
05-02-2018 2:12 PM - edited 05-02-2018 2:13 PM
Re: Topic Vanished?
05-02-2018 2:14 PM
Thanks! Guess it probably flagged it up from post length or something.
