Timed task on CGI server
- Everything else
- Timed task on CGI server
01-11-2015 11:01 AM
I'm wanting to run some code (preferably PHP) on an hourly basis in my CGI webspace. I can't see any simple way of doing this - could you point me in the right direction?
Message 1 of 3
(1,166 Views)
2 REPLIES 2
Re: Timed task on CGI server
01-11-2015 5:28 PM
Unfortunately we don't have access to cron to run such jobs. It might be possible to use an external cron service to trigger them remotely, though I haven't tried that. One problem could be that PHP command line would be the means to run the job, but only the CGI module is available to us.
If an approximation to an hour is acceptable, and you have a website with sufficiently frequent visitors one possibility is to use something like phpJobScheduler to start the required task. If you use WordPress, using a WP-Cron hook (plugin) might be an option. Again I've not tried either of these.
David
David
David
Message 2 of 3
(242 Views)
02-11-2015 3:05 PM
Hi David.
I thought that might be the case
I'll have a look at other options, like phpJobScheduler,. Thanks for your comments.
Kiwi
Kiwi
Message 3 of 3
(242 Views)
- Everything else
