The requested URL was rejected
- Everything else
- The requested URL was rejected
25-06-2015 11:29 AM
[tt]The requested URL was rejected. If you think this is an error, please contact the webmaster.
Your support ID is: 70357972616389479[/tt]
There is nothing wrong with the URL - if I type it in to the address bar I can go there no problem.
I have tried changing the URL behind the link and get the same error, so I guess it may be something in the program code that is causing the error.
Has anyone any ideas what this might be?
Re: The requested URL was rejected
25-06-2015 11:53 AM
25-06-2015 12:03 PM
25-06-2015 12:15 PM
dick:quote
25-06-2015 12:30 PM
Quote from: spraxyt This sounds like a corrupted cookie in your browser. You could try removing all cookies relating to the linked site from your browser, then try again.
Tried that but still get the same error.
30-06-2015 4:19 PM
15-07-2015 11:08 PM
The link used to work and I have not made any changes to the code, so something must have changed on the host to cause the problem. I'm not sure exactly when it started going wrong since this is a web page I access infrequently but I do know it was working OK back in Februrary.
Any ideas anyone?
16-07-2015 12:46 AM
03-08-2015 9:43 AM
Quote from: aenea Any ideas anyone?
I've raised a ticket with Hostopia. Thanks for the detailed explanation you provided
03-09-2015 10:40 AM
Quote from: aenea I raised a ticket as suggested but it got me nowhere. Response was that it must be a coding problem and Plusnet don't help with code.
Are you still able to replicate the problem? I've received a message from Hostopia to say that they've made some changes that should have improved the situation.
- Everything else
