Test your site
- Everything else
- Re: Test your site
Test your site
18-06-2008 11:17 PM
So you just designed the perfect website and you think it looks great then you get complaints that it doesnt work in Minefield 3.1 or Epiphany 2.22 what do you do.
Tryhttp://browsershots.org/ this site lets you see how your site looks in over 60 browsers. Its the most useful tool on the web,
You could then try a tune up at
http://www.submitplus.com/freeprograms.php?b=popularity which will let you do more testing on meta tags load times etc.
Message 1 of 5
(1,744 Views)
4 REPLIES 4
Re: Test your site
19-06-2008 11:57 AM
Very Clever
cp:red Please do not post in all CAPS as per link:rules mod:end
Message 2 of 5
(609 Views)
Re: Test your site
19-06-2008 4:45 PM
Not bad, 47 browsers tested - 1 can't use the minimal javascript (which hopefully will go away soon anyway), 1 can't display CSS correctly, and 1 is caught half-way loading.
Not too bad work from myself I don't think
Message 3 of 5
(609 Views)
Re: Test your site
19-06-2008 6:25 PM
I am really rather chuffed - as a complete novice in building websites I created one from scratch using CSS and it seems to work in everything except Dillo (doesn't support CSS) and IE4 on Windows XP (if anyone is still using that - tough)
Message 4 of 5
(609 Views)
Re: Test your site
19-06-2008 6:54 PM
IE 7.0 only shows blank. Is that true?
Thanks for the Link.
Message 5 of 5
(609 Views)
