Temporary website needed
- Everything else
- Re: Temporary website needed
08-09-2015 3:14 PM
Looking at PN hosting costs this seems prohibitive so two questions:-
1. The cost looks like >£100 as the site will probably be taken down after use thus incurring a hefty penalty: true?
2. Any better, reliable and cheap, suggestions?
TIA/
08-09-2015 3:21 PM
Your email would also filter into your existing mailboxes, which might not be what you desire if the domain is intended for use by the charity.
If a new domain needs registering, then there's an option to do so for £1/mnth. You would need to pay for a minimal of 12 months though IIRC.
08-09-2015 3:52 PM
The £1 option may be useful.
I've asked the organisation to find out the software involved plus data usage expected and will come back with data.
09-09-2015 9:13 AM
Quote from: Mardler 2. Any better, reliable and cheap, suggestions?
CloudAccess offer a FREE Joomla/WordPress hosting plan as well as the usual paid-for hosting plans. I've been using their FREE hosting plan for quite a while and it works very well but the only possible drawback is that once a month, you have to login to your Control Panel and "renew" your FREE hosting plan. If you don't "renew", your site gets deleted but they always send an email reminder a couple of days before the "renewal" is due. Might be worth having a look
09-09-2015 10:39 AM
09-09-2015 12:21 PM
01-10-2015 4:18 PM
- Everything else
