TXT and SRV records in DNS
- Everything else
- TXT and SRV records in DNS
27-10-2011 5:04 PM
I want to create some TXT and SRV records in DNS to point at some third party servers.
I am told Plus.net do not support this. A search on here turned up an old thread of recommended DNS services.
Anyone managed to find a workaround?
Does anyone have any recommendations for DNS hosting services that they are using that ismore flexible?
I suppose the alternative is to find another ISP that is more flexible. Any recommendations? Would be the last resort as I have been with plus.net for a long time but I do like a one stop shop that covers all my needs. DNS service is sadly a bit limited here. I am sure before BT it was more flexible.
Many Thanks
Robert
Many Thanks
Robert
Message 1 of 8
(14,937 Views)
7 REPLIES 7
Re: TXT and SRV records in DNS
27-10-2011 6:40 PM
Who is your domain Registrar and don't they offer DNS service?
Message 2 of 8
(753 Views)
27-10-2011 8:08 PM
Both registered and hosted at plus.net so no they do not support.
Just looking at moving dns to daily.co.uk or shifting whole lot to talktalk. Waiting for their responses to see if they have support.
Have had good experience with plus.net so not wanting to change. Could be frying pan to fire.
Message 3 of 8
(753 Views)
28-10-2011 12:14 AM
Quote from: tssrmacdonald Could be frying pan to fire.
Nah - more like frying pan to inferno.
Message 4 of 8
(753 Views)
28-10-2011 1:10 PM
I ended up self hosting my DNS.
Fasthosts.co.uk offer records for SPF, TXT and SRV (as well as the usual mix of MX, CNAME, A, AAAA) and seem to be simple enough to use, they could be worth a look.
Message 5 of 8
(753 Views)
28-10-2011 4:31 PM
Quote from: tssrmacdonald Both registered and hosted at plus.net so no they do not support.
So I assume that you are paying £54 per year for registration when the normal rate is approximately £7 with other registrars.
I use Fasthost and I have both TXT and SPF records.
Also between ourselves as PN when they host your site also want to host the DNS it is possible to split these 2 functions.
Message 6 of 8
(753 Views)
28-10-2011 5:50 PM
Quote from: tssrmacdonald DNS service is sadly a bit limited here. I am sure before BT it was more flexible.
Nope. I moved my DNS records away in 2003 for the same reason - no SRV records. A re-write of the DNS system was imminent at that point - planned for 'before Christmas' according to the esteemed Mr Wild (of blessed memory - Hi Ian!). Unfortunately, they had omitted to mention which Christmas they had in mind. Clearly not 2011 either.
Message 7 of 8
(753 Views)
31-10-2011 6:52 PM
I'm pretty sure that Pay as you Host (Plusnets sister company) offer TXT and SRV records, might be worth raising a ticket on your account to ask about it... it's the same people managing your domain at the end of the day then:
http://www.inuk.com/
Message 8 of 8
(753 Views)
- Everything else
