TV connection
- Everything else
- TV connection
TV connection
09-12-2016 7:19 PM
Hi, I'm not sure if this is the right place to ask, but I've just got a new smart tv and the freesat connection into the tv is very loose, I think I need a new nut type thing to keep it screwed in. Could anyone tell me the name of the connector I need? Thanks.
Re: TV connection
09-12-2016 7:48 PM - edited 09-12-2016 7:56 PM
An 'F' connector maybe
Available from Amazon
They don't usually wear loose, they just need tightening up.
It wouldn't be the first time I have used a small spanner to help things along.
As long as it's not cross threaded.
Customer and Forum Moderator. Windows 10 Firefox 100.0.1 (64-bit (64-bit)
Re: TV connection
09-12-2016 8:04 PM
Thanks Strat, I think that's what I need, on my connector the nut is just turning, I think it's too big but I'll have another look.
Re: TV connection
09-12-2016 8:46 PM
When screwing in the connector try to hold the cable with you other hand to take the weight off the nut as you screw it in. I have just done the same to my new TV that I got the other day so I'm mentioning this having been there and just done that.
Re: TV connection
09-12-2016 8:51 PM
Thanks Mook, I'll give it another go before I buy another one, I think that the copper needs to be cut back a bit more as well.
