Supported Domain Extensions
- Everything else
- Supported Domain Extensions
28-08-2013 1:25 PM
Good Afternoon,
Can anyone tell me which domain extensions are supported by Plusnet? This is for Hosting-Only - not Full Control.
eg. If I had say a .be domain and pointed it at the plusnet nameservers would I be able to use it on my static IP?
Many Thanks
Many Thanks
Message 1 of 7
(1,711 Views)
6 REPLIES 6
Re: Supported Domain Extensions
29-08-2013 7:08 AM
Anyone?
Got a .co domain I want to register but there's no point if I can't use it with plus net
Message 2 of 7
(526 Views)
29-08-2013 7:52 AM
Is there any particular reason why you want to use Plusnet's nameservers rather than those provided by your chosen registrar?
Message 3 of 7
(526 Views)
29-08-2013 10:16 AM
Thanks for the reply.
Can you explain the process of doing that? You don't mean Domain forwarding do you?
I want my Hostname/ IP reverse DNS to be "domain.com" rather than username.plus.net hence the reason I thought I had to point the domain at the plusnet nameservers?
Message 4 of 7
(526 Views)
29-08-2013 10:41 AM
If you ask Plusnet to set the rDNS entry for your IP they should be able to configure it to be 'yourdomain.tld' as needed. The nameservers that currently host your domain can be used to point 'yourdomain.tld' to your IP address. You'll need to make sure the entry is made (and propagated) on the forward nameserver before Plusnet will change the reverse.
There shouldn't be any need for Plusnet to actually host your domain.
Message 5 of 7
(526 Views)
29-08-2013 10:53 AM
This explains it
https://www.plus.net/wizard/?p=wizard&page=22425&wizard_id=38
Quote * The domain name may be any domain already hosted on your Plusnet account. We can also delegate rDNS to a non-hosted domain however you must create the forward DNS record first. We may also ask you to provide proof of ownership of the domain, for example a scanned copy of the domain registration certificate. The hostname can be anything (sensible!), but it is only possible to have a single subdomain (ie host.host.domain is not possible). If you have a block of IP addresses you can request one hostname for each IP.
Message 6 of 7
(526 Views)
29-08-2013 3:11 PM
Thanks chaps.
Much appreciated.
Much appreciated.
Message 7 of 7
(526 Views)
- Everything else
