Support ticket login problem
FIXED- Subscribe to RSS Feed
- Everything else
- Support ticket login problem
20-07-2017 7:27 AM
I've pulled this subject out of another subject elsewhere as it's now a completely separate matter.
I'm a Freenetname/Madasafish user now subsumed into the Plusnet quagmire... 🙂
I do understand the difficulties when attempting to pull two disparate systems together... But now as a User, I'm the one with the problems.
It relates to Spam settings and filters, but now specifically not being able to login to a support ticket I've been informed has been updated by an email note from FNN/Madas support..
I log in to my FNN/Madas account, navigate to the link for the active ticket, it requires me to login again.
I do so with the same details I use to get me logged into my FNN/Madas account a few second earlier, it is rejected.
It doesn't matter if I write in the data manually (Correctly) or copy and paste from the dialogue to my FNN/Madas account which is accepted, the ticket login always fails.
This has happened with past support tickets, and I just gave up even after Live chat said they would look into it and obviously never did.
Monday 17th I received the email notification, I've been trying since then to login to the ticket, all failing.
Yesterday I spoke to Live chat about the problem , yes there is a problem but no one seems to know what the problem is, or how to sort it out.
Hahahahahahaha! From this users perspective it's quite simple, I can't login, because the system for name and password authentication is BROKEN.
So Boys and Girls at Plusnet, how do I get to login to my ticket?
Arturox
Fixed! Go to the fix.
20-07-2017 3:20 PM
Hi @Arutrox, I've discussed this with a few colleagues, and while not an ideal situation, as a bit of a workaround you should be able to view the tickets by logging in directly here: https://secure.madasafish.com/contact/tickets.shtml
I hope this helps.
Re: Support ticket login problem
20-07-2017 4:39 PM
Hi HarryB,
Thanks for that the direct link it worked so I've been able to reply to the ticket.
Appreciate your efforts.
Ax
20-07-2017 5:31 PM
23-07-2017 6:52 AM
Final note on this subject...
While the workaround does work, and the behind the scenes folks are now aware of it, that's a good start...
So thanks again for the support and goodbye.
Arturox
23-07-2017 4:11 PM
Moderator's note by Mike (Mav): I have changed the fix to @HarryB as per message #2.
Forum Moderator and Customer
- Everything else
