Subdomains and ccgi
Boxersoft
Subdomains and ccgi
I've not done anything with my web space for ages. I'm now coming back to it, probably for the first time since the change to the new ccgi setup, and having a few teething problems. My DNS records are set to:
Left field Type Right field
mydomain.co.uk.a 84.92.1.4
wwwcname ccgi.plus.net.
mysub cname ccgi.plus.net.
The idea was to allow visitors to access my main site either as just mydomain.co.uk or www.mydomain.uk, and to redirect mysub.mydomain.co.uk to a subdirectory (using mod_rewrite in .htaccess) as a testing ground. I think it used to work previously but it's not working now. I assumed my mod_rewrites needed tweaking but it doesn't look like requests to anything other than the www subdomain are getting there at all (not even the plain domain name without the www).
Do I need to change something in the DNS settings?
7 REPLIES 7
bobpullen
Fixes: 290
Re: Subdomains and ccgi
Two problems:
1. The IP address of the server has changed following the migration. I've corrected the A record for you; allow 24 hours or so for DNS to catch up.
2. The new CGI platform has no knowledge of your two sub-domains so will refuse to serve pages for them. I've since added them, so this should now work as expected.
Boxersoft
OK, thanks. I'm surprised that it was working at all with the wrong IP address, but there you go.
Quote from: Bob
Is there a mechanism for customers to create subdomains themselves or is it something that has to be done for us (i.e. raise a ticket)?
The two existing subdomains seem to be working straight away for me, but the plain (non-www) address isn't. Can I expect that to start working after propagation of the correct IP address around the DNS servers or is that a separate issue?
bobpullen
Fixes: 290
Quote from: Boxersoft
Can only be done by a support agent.
The two existing subdomains seem to be working straight away for me, but the plain (non-www) address isn't. Can I expect that to start working after propagation of the correct IP address around the DNS servers...
Yes, it will work once DNS has had the chance to propagate.
Boxersoft
OK, thanks.
oliverb
Any chance you could look at mine?
I would like to add a ccgi subdomain to  coaxialpower.com
I've raised a ticket and had a response that it has been set up but its still returning "Not Authorized to View This Page [CFN #0004]".
bobpullen
Fixes: 290
Should be sorted now.
oliverb
Thanks, that seems to have done it!
