Static IP
FIXED- Subscribe to RSS Feed
- Everything else
- Static IP
20-07-2019 11:38 AM
Hi all knowledgeable folks,
Re: a plus net static ip, Can reverse DNS be customised?
Fixed! Go to the fix.
Re: Static IP
20-07-2019 11:50 AM
I believe rDNS can be configured to one of the following:-
1 - username.plus.com – This is the default setting.
2 - IP.plus.com - 1-1-1-1.plus.com as an example.
3 - anything.domain.com - e.g. mail.bbc.co.uk – To use this option you will need to configure the forward record on the domain. We are required to prove you own the domain before any changes can be made and this will serve as verification. The domain can be hosted on the account or externally.
You used to request it via a ticket but probably best to wait fro one of the PN help team to spot this and advise of the best way nowadays...
21-07-2019 9:03 AM
Hi there.
Yes it can be configured using one of the above options @MisterW has advised.
While you can't raise a ticket anymore for the majority of topics, you can still raise a ticket for this particular query by going here: https://www.plus.net/wizard/
Feel free to nudge us over here when/if you open a ticket and we'll be happy to pick it up.
Re: Static IP
21-07-2019 12:54 PM
Thanks for this. but it won't allow me to raise a new ticket.
Re: Static IP
21-07-2019 12:58 PM
This topic has been moved from ADSL Broadband to Everything else.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
Re: Static IP
21-07-2019 12:59 PM
@oldblokeh can you PM me your account username so I can investigate further?
Re: Static IP
21-07-2019 1:15 PM
For some reason your reply was attached to the wrong post! However, I'll PM you..
Cheers,
Re: Static IP
21-07-2019 1:17 PM
Re: Static IP
21-07-2019 8:23 PM
@Gandalf Cheers, home move first.
