Static IP
its-me
Static IP
Hi all knowledgeable folks,
Re: a plus net static ip, Can reverse DNS be customised?Huh
8 REPLIES 8
Fixes: 394
Re: Static IP
I believe rDNS can be configured to one of the following:-
1 - username.plus.com – This is the default setting.
2 - IP.plus.com - 1-1-1-1.plus.com as an example.
3 - anything.domain.com - e.g. mail.bbc.co.uk – To use this option you will need to configure the forward record on the domain. We are required to prove you own the domain before any changes can be made and this will serve as verification. The domain can be hosted on the account or externally.
You used to request it via a ticket but probably best to wait fro one of the PN help team to spot this and advise of the best way nowadays...
Fixes: 1,600
Re: Static IP
Hi there.
Yes it can be configured using one of the above options @MisterW has advised.
While you can't raise a ticket anymore for the majority of topics, you can still raise a ticket for this particular query by going here: https://www.plus.net/wizard/
Feel free to nudge us over here when/if you open a ticket and we'll be happy to pick it up.
oldblokeh
Re: Static IP
Thanks for this. but it won't allow me to raise a new ticket.
Strat
Fixes: 565
Re: Static IP
Moderators Note
This topic has been moved from ADSL Broadband to Everything else.
Fixes: 1,600
Re: Static IP
@oldblokeh can you PM me your account username so I can investigate further?
oldblokeh
Re: Static IP
For some reason your reply was attached to the wrong post! However, I'll PM you..
Cheers,
Fixes: 1,600
Re: Static IP
No problem
its-me
Re: Static IP
@Gandalf Cheers, home move first.
