Static IP request
- Everything else
- Static IP request
Static IP request
25-08-2023 10:27 AM
I would like to enable a static IP-address, but I can't do it in the portal.
Can you help me?
Thank you in advance!
Can you help me?
Labels:
Message 1 of 4
(1,322 Views)
3 REPLIES 3
Re: Static IP request
25-08-2023 12:18 PM
@naglya it will be a one off fee of £5 are you ok for that?
Message 2 of 4
(1,297 Views)
25-08-2023 11:54 PM
Sure.
Thank you very much!
Message 3 of 4
(1,265 Views)
27-08-2023 3:38 PM
Hi @naglya
That's been sorted for you now and if you reboot the router you'll pick it up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Message 4 of 4
(1,226 Views)
