Static IP not static after house move
eludlow123
Hi there. Have a planet static. Moved house on Friday and all was good.
Noticed this morning the connection had a different IP after I briefly cut the power. I’ve reconnected my router a few times and it’s getting a dynamic IP each time now.
Presumably nothing I can do this end - and so I need to speak to Plusnet support tomorrow?
Thanks.
4 REPLIES 4
Fixes: 385
Re: Static IP not static after house move
@eludlow123 Speaking to support may get you somewhere - IF you get an agent that knows what a static IP is.
Just in case they 'can't help' I'll tag the Help Team - @Windings ?
eludlow123
Thank you!
Fixes: 1,662
Hey,
Should be sorted now, could you turn your router off and on?
eludlow123
Yes all good - thank you very much!
