Static IP 'lost'
Re: Static IP 'lost'
@Peterworks
That's an unexpected result!
Was at some point your Hub not logged in as you?
Is the apparent correction of IP address an issue?
Edit: The option to add/check the Static IP was found in Add-Ons in the members centre, but that has now been taken away.
Peterworks
@Dan_the_Van
My hub has always been logged in as me.
Yes the loss of the static IP is an issue.
Peterworks
Update.
Contacted support and confusion reigned. It is being progressed to management !
@Peterworks
It is an unusual case.
@Leanne_T
Anything you can do to ensure the correct team is enganged?
RealAleMadrid
Fixes: 68
@Peterworks  If your current IP look up is showing your Username then it is a static IP, obviously a different one. RDNS for a dynamic address is "reversedIPaddress".dyn.plus.net
Fixes: 1,665
I've had a look into this and can confirm you still have a static IP however it's applied as a "Force L2TP Connectivity" component, due to the broadband firewall being active, which means it's not guaranteed to allocate you the same one.
I can apply a fixed static IP to your account now, if it helps? You would get a new one, but it shouldn't change again.
Peterworks
@Gandalf
Thank you - please apply a fixed static IP to my account. I appreciate that it will not be the same as the previous one but that is okay. What sort of timing on this please ?
Thank you again
Fixes: 1,665
Just done it now. If you can reboot your router or disconnect/reconnect the PPP session, you'll get the new static IP.
Peterworks
@Gandalf
Many thanks
and many thanks to all who responded.
Fixes: 251
That is most interesting!!
@Peterworks wrote:
If they can't fix it can I have my five pounds back ?
Suggests that Peter paid for a static IP.
Question: How does a static IP by selection (as in paid for) interplay with someone also using the broadband fire wall.
ExForce9
All Star
Fixes: 11
@Townman
The first thing I thought of when I saw that, was whether that was the cause of your post  IPv6 trial - Plusnet firewall
pvmb
Champion
Fixes: 17
There must be more to it than that. I have a static IP and rDNS returns <IP>.plus.com
It used to be possible to request removal of your Username from rDNS lookup, which I asked for. It may still be possible.
Fixes: 585
@pvmb it is still possible to change the rDNS for a static IP.
The options are <accountname>.plus.com , <ip>.plus.com or a domain url for a domain you own (and have set an A record to point to your static IP)
A dynamic IP always shows <IP>.dyn.plus.net.
so if the rDNS returns <accountname>.plus.com it MUST be a static IP
Fixes: 251
@ExForce9 wrote:
@Townman
AIUI it is associated, but not the cause.
I needed to fiddle with my broadband firewall settings, though that did not change my static IP address, it did drop me off the IPv6 trial, as that component is (in someway) connected to the firewall settings (IIRC Dave's advice).
