Static IP address
stonehouse
Static IP address
Hi.
I used to have a static IP address before I changed to full fibre. Should the static address service have come with me when I moved or is it different on the FF packages?
Thanks.
Chris.
2 REPLIES 2
Fixes: 387
Re: Static IP address
It should - you will need a PN staff member to sort this.
Fixes: 1,662
Hi Chris,
Your static IP is fine, but your router's not authenticating correctly, which is causing it to be assigned a dynamic IP.
Please could you private message me the serial number and the last 4 digits of the MAC from the label on the router?
With that, I should be able to sort things.
